PRADIOS
Форматы и расширения файлов
Единый входной файл
Новые ключевые слова в PRADIOS 2025
Входные данные для стартера
Общие сведения
Алфавитный список записей блоков данных
См. также
/ACCEL
/ACTIV
/ADMAS
/ADMESH/GLOBAL
/ADMESH/SET
/ADMESH/STATE/SH3N
/ADMESH/STATE/SHELL
/ALE/BCS
/ALE/CLOSE
/ALE/GRID/DISP
/ALE/GRID/DONEA
/ALE/GRID/FLOW-TRACKING
/ALE/GRID/LAPLACIAN
/ALE/GRID/SPRING
/ALE/GRID/STANDARD
/ALE/GRID/VOLUME
/ALE/GRID/ZERO
/ALE/LINK/VEL
/ALE/MAT
/ALE/MUSCL
/ALE/SOLVER/FINT
/AMS
/ANALY
/ANIM/VERS
/BCS/CYCLIC
/BCS/LAGMUL
/BCS
/BCS/WALL
/BEAM
/BEGIN
/BEM/DAA
/BOX/BOX
/BOX/CYLIN
/BOX/RECTA
/BOX/SPHER
Коробки
/BRIC20
/BRICK
/CHECK/RFILE/OFF
/CLOAD
/CLUSTER
/CNODE
Ограничения — Starter Input (Обзор)
/CONVEC
/CYL_JOINT
/DAMP/FREQUENCY_RANGE
/DAMP/INTER
/DAMP
/DAMP/VREL
/DEF_SHELL
/DEF_SOLID
/DEFAULT/INTER/TYPE11
/DEFAULT/INTER/TYPE19
/DEFAULT/INTER/TYPE24
/DEFAULT/INTER/TYPE25
/DEFAULT/INTER/TYPE7
/DFS/DETCORD
/DFS/DETLINE/NODE
/DFS/DETLINE
/DFS/DETPLAN/NODE
/DFS/DETPLAN
/DFS/DETPOINT/NODE
/DFS/DETPOINT/SET
/DFS/DETPOINT
/DFS/LASER
/DFS/WAV_SHA
/DRAPE
/EBCS/FLUXOUT
/EBCS/GRADP0
/EBCS/INIP
/EBCS/INIV
/EBCS/INLET
/EBCS/MONVOL
/EBCS/NORMV
/EBCS/NRF
/EBCS/PRES
/EBCS/VALVIN
/EBCS/VALVOUT
/EBCS/VEL
/EIG
/ENCRYPT
/EOS/COMPACTION2
/EOS/COMPACTION
/EOS/EXPONENTIAL
/EOS/GRUNEISEN
/EOS/IDEAL-GAS or /EOS/IDEAL-GAS-VE
/EOS/IDEAL-GAS-VT
/EOS/LINEAR
/EOS/LSZK
/EOS/MURNAGHAN
/EOS/NASG
/EOS/NOBLE-ABEL
/EOS/OSBORNE
/EOS/POLYNOMIAL
/EOS/PUFF
/EOS/SESAME
/EOS/STIFF-GAS
/EOS/TABULATED
/EOS/TILLOTSON
/EREF
/EULER/MAT
/FAIL/ALTER
/FAIL/BIQUAD
/FAIL/CHANG
/FAIL/COCKCROFT
/FAIL/CONNECT
/FAIL/EMC
/FAIL/ENERGY
/FAIL/FABRIC
/FAIL/FLD
/FAIL/FRACTAL_DMG
/FAIL/GENE1
/FAIL/GURSON
/FAIL/HASHIN
/FAIL/HC_DSSE
/FAIL/HOFFMAN
/FAIL/INIEVO
/FAIL/JOHNSON
/FAIL/LAD_DAMA
/FAIL/MAXSTRAIN
/FAIL/MULLINS_OR
/FAIL/NXT
/FAIL/ORTHBIQUAD
/FAIL/ORTHENERG
/FAIL/PUCK
/FAIL/RTCL
/FAIL/SAHRAEI
/FAIL/SNCONNECT
/FAIL/SPALLING
/FAIL/SYAZWAN
/FAIL/TAB1
/FAIL/TAB2
/FAIL/TBUTCHER
/FAIL/TENSSTRAIN
/FAIL/TSAIHILL
/FAIL/TSAIWU
/FAIL/USERi
/FAIL/VISUAL
/FAIL/WIERZBICKI
/FAIL/WILKINS
Модели отказов
/FRAME/FIX
/FRAME/MOV2
/FRAME/MOV
/FRAME/NOD
/FRIC_ORIENT
/FRICTION
/FUNC_2D
/FUNCT_PYTHON
/FUNCT_SMOOTH
/FUNCT
/FXBODY
/GAUGE/POINT
/GAUGE/SPH
/GAUGE
/GJOINT
/GRAV
/GRBEAM
/GRBRIC
/GRNOD
/GRPART
/GRQUAD
/GRSH3N
/GRSHEL
/GRSPRI
/GRTRIA
/GRTRUS
/HEAT/MAT
/IMPACC
/IMPDISP/FGEO
/IMPDISP
/IMPFLUX
/IMPLICIT
/IMPTEMP
/IMPVEL/FGEO
/IMPVEL/LAGMUL
/IMPVEL
/INCLUDE_LS-DYNA
#include
/INIBEAM/AUX
/INIBEAM/FULL
/INIBEAM
/INIBRI/AUX
/INIBRI/DENS
/INIBRI/ENER
/INIBRI/EPSP
/INIBRI/EREF
/INIBRI/FAIL
/INIBRI/FILL
/INIBRI/ORTHO
/INIBRI/SCALE_YLD
/INIBRI
/INIBRI/STRA_F
/INIBRI/STRA_FGLO
/INIBRI/STRESS
/INIBRI/STRS_F
/INIBRI/STRS_FGLO
/INICRACK
/INIGRAV
/INIMAP1D/FILE
/INIMAP1D
/INIMAP2D/FILE
/INIMAP2D
/INIQUA/DENS
/INIQUA/ENER
/INIQUA/EPSP
/INIQUA
/INIQUA/STRESS
/INISHE/FAIL or /INISH3/FAIL
/INISHE/AUX or /INISH3/AUX
/INISHE/EPSP_F or /INISH3/EPSP_F
/INISHE/EPSP or /INISH3/EPSP
/INISHE/ORTH_LOC or /INISH3/ORTH_LOC
/INISHE/ORTHO or /INISH3/ORTHO
/INISHE/SCALE_YLD or /INISH3/SCALE_YLD
/INISHE/STRA_F/GLOB or /INISH3/STRA_F/GLOB
/INISHE/STRA_F or /INISH3/STRA_F
/INISHE/STRS_F/GLOB or /INISH3/STRS_F/GLOB
/INISHE/THICK or /INISH3/THICK
/INISPHCEL/FULL
/INISPRI/FULL
/INISTA
/INITEMP
/INITRUSS/FULL
/INIVEL/AXIS
/INIVEL/FVM
/INIVEL/NODE
/INIVEL
/INIVOL
/INTER/HERTZ/TYPE17
/INTER/LAGDT/TYPE7
/INTER/LAGMUL/TYPE16
/INTER/LAGMUL/TYPE17
/INTER/LAGMUL/TYPE2
/INTER/LAGMUL/TYPE7
/INTER/SUB
/INTER/TYPE10
/INTER/TYPE11
/INTER/TYPE12
/INTER/TYPE14
/INTER/TYPE15
/INTER/TYPE18
/INTER/TYPE19
/INTER/TYPE1
/INTER/TYPE21
/INTER/TYPE23
/INTER/TYPE24
/INTER/TYPE25
/INTER/TYPE2
/INTER/TYPE3
/INTER/TYPE5
/INTER/TYPE6
/INTER/TYPE7
/INTER/TYPE8
/INTER/TYPE9
/IOFLAG
/KEY
/LAGMUL
/LEAK/MAT
/LINE/BOX or /LINE/BOX2
/LINE/EDGE
/LINE/GRBEAM
/LINE/GRSPRI
/LINE/GRTRUS
/LINE/LINE
/LINE/MAT
/LINE/PART
/LINE/PROP
/LINE/SEG
/LINE/SUBMODEL
/LINE/SUBSET
/LINE/SURF
Линии
/LOAD/PCYL
/LOAD/PFLUID
/LOAD/PRESSURE
/LOAD/CENTRI
/MADYMO/EXFEM
/MAT/B-K-EPS
/MAT/GAS
/MAT/LAW0 (VOID)
/MAT/LAW100 (MNF)
/MAT/LAW101
/MAT/LAW102 (DPRAG2)
/MAT/LAW103 (HENSEL-SPITTEL)
/MAT/LAW104 (JOHNS_VOCE_DRUCKER)
/MAT/LAW106 (JCOOK_ALM)
/MAT/LAW108 (SPR_GENE)
/MAT/LAW10 (DPRAG1)
/MAT/LAW111
/MAT/LAW112 (PAPER or XIA)
/MAT/LAW113 (SPR_BEAM)
/MAT/LAW114 (SPR_SEATBELT)
/MAT/LAW115 (DESHFLECK)
/MAT/LAW116
/MAT/LAW117
/MAT/LAW119 (SH_SEATBELT)
/MAT/LAW11 (BOUND)
/MAT/LAW120 (TAPO)
/MAT/LAW121 (PLAS_RATE)
/MAT/LAW122 (MODIFIED_LADEVEZE)
/MAT/LAW124 (CDPM2)
/MAT/LAW126 (JOHNSON_HOLMQUIST_CONCRETE)
/MAT/LAW12 (3D_COMP)
/MAT/LAW14 (COMPSO)
/MAT/LAW15 (CHANG)
/MAT/LAW169 (ARUP_ADHESIVE)
/MAT/LAW16 (GRAY)
/MAT/LAW18 (THERM)
/MAT/LAW19 (FABRI)
/MAT/LAW1 (ELAST)
/MAT/LAW200 (MDS)
/MAT/LAW20 (BIMAT)
/MAT/LAW21 (DPRAG)
/MAT/LAW22 (DAMA)
/MAT/LAW23 (PLAS_DAMA)
/MAT/LAW24 (CONC)
/MAT/LAW25 (COMPSH)
/MAT/LAW26 (SESAM)
/MAT/LAW27 (PLAS_BRIT)
/MAT/LAW28 (HONEYCOMB)
/MAT/LAW2 (PLAS_JOHNS)
/MAT/LAW32 (HILL)
/MAT/LAW33 (FOAM_PLAS)
/MAT/LAW34 (BOLTZMAN)
/MAT/LAW35 (FOAM_VISC)
/MAT/LAW36 (PLAS_TAB)
/MAT/LAW37 (BIPHAS)
/MAT/LAW38 (VISC_TAB)
/MAT/LAW3 (HYDPLA)
/MAT/LAW40 (KELVINMAX)
/MAT/LAW42 (OGDEN)
/MAT/LAW43 (HILL_TAB)
/MAT/LAW44 (COWPER)
/MAT/LAW46 (LES_FLUID)
/MAT/LAW48 (ZHAO)
/MAT/LAW49 (STEINB)
/MAT/LAW4 (HYD_JCOOK)
/MAT/LAW50 (VISC_HONEY)
/MAT/LAW51 (MULTIMAT)
/MAT/LAW52 (GURSON)
/MAT/LAW54 (PREDIT)
/MAT/LAW57 (BARLAT3)
/MAT/LAW58 (FABR_A)
/MAT/LAW59 (CONNECT)
/MAT/LAW5 (JWL)
/MAT/LAW60 (PLAS_T3)
/MAT/LAW62 (VISC_HYP)
/MAT/LAW63 (HANSEL)
/MAT/LAW64 (UGINE_ALZ)
/MAT/LAW65 (ELASTOMER)
/MAT/LAW66
/MAT/LAW68 (COSSER)
/MAT/LAW69
/MAT/LAW6 (HYDRO or HYD_VISC)
/MAT/K-EPS
/MAT/LAW70 (FOAM_TAB)
/MAT/LAW71
/MAT/LAW72 (HILL_MMC)
/MAT/LAW73
/MAT/LAW74
/MAT/LAW75 (POROUS)
/MAT/LAW76 (SAMP)
/MAT/LAW77
/MAT/LAW78
/MAT/LAW79 (JOHN_HOLM)
/MAT/LAW80
/MAT/LAW81 (DPRAG_CAP)
/MAT/LAW82
/MAT/LAW83
/MAT/LAW84
/MAT/LAW87 (BARLAT2000)
/MAT/LAW88
/MAT/LAW90
/MAT/LAW92
/MAT/LAW93 (ORTH_HILL) or (CONVERSE)
/MAT/LAW94 (YEOH)
/MAT/LAW95 (BERGSTROM_BOYCE)
/MAT/LAW97 (JWLB)
/MAT/LAW151 (MULTIFLUID)
/MAT/LAW41 (LEE_TARVER)
/MAT/LAW53 (TSAI_TAB)
/MAT/PLAS_PREDEF
/MAT/PLAS_ZERIL
/MAT/USERij
/MERGE/RBODY
/MONVOL/AIRBAG1
/MONVOL/AREA
/MONVOL/COMMU1
/MONVOL/FVMBAG1
/MONVOL/FVMBAG2
/MONVOL/GAS
/MONVOL/LFLUID
/MONVOL/PRES
/MOVE_FUNCT
/MPC
/NBCS
/NODE
/NONLOCAL/MAT
/PARAMETER
/PART
/PENTA6
/PERTURB/FAIL/BIQUAD
/PERTURB/PART/SHELL
/PERTURB/PART/SOLID
/PERTURB (Obsolete)
/PLOAD
/PLY
/PRELOAD/AXIAL
/PRELOAD
/PROP/INJECT1
/PROP/INJECT2
/PROP/PCOMPP
/PROP/TYPE0 (VOID)
/PROP/TYPE10 (SH_COMP)
/PROP/TYPE11 (SH_SANDW)
/PROP/TYPE12 (SPR_PUL)
/PROP/TYPE13 (SPR_BEAM)
/PROP/TYPE14 (SOLID)
/PROP/TYPE15 (POROUS)
/PROP/TYPE16 (SH_FABR)
/PROP/TYPE17 (STACK)
/PROP/TYPE18 (INT_BEAM)
/PROP/TYPE19 (PLY)
/PROP/TYPE1 (SHELL)
/PROP/TYPE20 (TSHELL)
/PROP/TYPE21 (TSH_ORTH)
/PROP/TYPE22 (TSH_COMP)
/PROP/TYPE23 (SPR_MAT)
/PROP/TYPE25 (SPR_AXI)
/PROP/TYPE26 (SPR_TAB)
/PROP/TYPE27 (SPR_BDAMP)
/PROP/TYPE28 (NSTRAND)
/PROP/TYPE2 (TRUSS)
/PROP/TYPE32 (SPR_PRE)
/PROP/TYPE33 (KJOINT)
/PROP/TYPE34 (SPH)
/PROP/TYPE35 (STITCH)
/PROP/TYPE36 (PREDIT)
/PROP/TYPE3 (BEAM)
/PROP/TYPE43 (CONNECT)
/PROP/TYPE44 (SPR_CRUS)
/PROP/TYPE45 (KJOINT2)
/PROP/TYPE46 (SPR_MUSCLE)
/PROP/TYPE4 (SPRING)
/PROP/TYPE51
/PROP/TYPE6 (SOL_ORTH)
/PROP/TYPE8 (SPR_GENE)
/PROP/TYPE9 (SH_ORTH)
/PROP/TYPE29, /PROP/TYPE30 or /PROP/TYPE31
/QUAD
/RADIATION
/RANDOM
/RBE2
/RBE3
/RBODY/LAGMUL
/RBODY
/REFSTA
/RETRACTOR/SPRING
/RLINK
/RWALL/LAGMUL
/RWALL
/RWALL/THERM
/SECT/CIRCLE
/SECT/PARAL
/SECT
/SENSOR/ACCE
/SENSOR/AND_OR
/SENSOR/DIST
/SENSOR/DIST_SURF
/SENSOR/ENERGY
/SENSOR/GAUGE
/SENSOR/HIC
/SENSOR/INTER
/SENSOR/NIC_NIJ
/SENSOR/NOT
/SENSOR/PYTHON
/SENSOR/RBODY
/SENSOR/RWALL
/SENSOR/SECT
/SENSOR/SENS
Датчики
/SENSOR/TEMP
/SENSOR/TIME
/SENSOR/USER1, /SENSOR/USER2 or /SENSOR/USER3
/SENSOR/VEL
/SENSOR/WORK
/SET
/SH3N
/SHEL16
/SHELL
/SKEW/FIX
/SKEW/MOV2
/SKEW/MOV
/SLIPRING/SHELL
/SLIPRING/SPRING
/SPH/INOUT
/SPH/RESERVE
/SPHBCS
/SPHCEL
/SPHGLO
/SPRING
/STACK
/STAMPING
/STATE/STR_FILE
//SUBMODEL
/SUBSET
/SURF/BOX or /SURF/BOX2
/SURF/DSURF
/SURF/ELLIPS
/SURF/GRBRIC/EXT
/SURF/GRBRIC/FREE
/SURF/GRSH3N
/SURF/GRSHEL
/SURF/MAT
/SURF/PART
/SURF/PLANE
/SURF/PROP
/SURF/SEG
/SURF/SUBMODEL
/SURF/SUBSET
/SURF/SURF
Поверхности
/TABLE/0
/TABLE/1
/TETRA10
/TETRA4
/TH/ACCEL
/TH/BEAM
/TH/BRIC
/TH/CLUSTER
/TH/CYL_JO
/TH/FRAME
/TH/FXBODY
/TH/GAUGE
/TH/INTER
/TH/MONVOL
/TH/NODE
/TH/NSTRAND
/TH/PART
/TH/QUAD
/TH/RBODY
/TH/RETRACTOR
/TH/RWALL
/TH/SECTIO
/TH/SENSOR
/TH/SH3N
/TH/SHEL
/TH/SLIPRING
/TH/SPH_FLOW
/TH/SPHCEL
/TH/SPRING
/TH/SUBS
/TH/SURF
/TH/TRIA
/TH/TRUSS
/THERM_STRESS/MAT
/THPART/GRBEAM
/THPART/GRBRIC
/THPART/GRQUAD
/THPART/GRSH3N
/THPART/GRSHEL
/THPART/GRSPRI
/THPART/GRTRUS
Временные истории
Временные истории (определения деталей)
/TITLE
/TRANSFORM/MATRIX
/TRANSFORM/POSITION
/TRANSFORM/ROT
/TRANSFORM/SCA
/TRANSFORM/SYM
/TRANSFORM/TRA
Преобразует
/TRIA
/TRUSS
/UNIT
/UPWIND (Obsolete)
/VISC/LPRONY
/VISC/PLAS
/VISC/PRONY
/XELEM
/XREF
Входные данные для Engine
LS-DYNA Входные Данные
Многодоменная Среда
Устаревшие ключевые слова
Другие файлы
Определения
PRADIOS
/STAMPING
View page source
/STAMPING
Ключевое слово формата блока. Эта опция позволяет адаптировать сообщения об ошибках к
приложения для штамповки.
/STAMPING
/STAMPING
/STAMPING
/STAMPING
/STAMPING
/STAMPING
/STAMPING
/STAMPING
/STAMPING
/STAMPING
